Remove step info from TestStand report
Hello all,
I want to remove the step info or merge it into loop indices (highlighted in image), It increases the steps in report. Please help.
(988 Views)
If I understand the problem, disabling results recording option for this step should work for you. See https://zone.ni.com/reference/en-XX/help/370052AA-01/tsref/infotopics/db_step_prop_run_opt_tab/
Alternatively you can always try to tweak the result list.
Michał Bieńkowski
CLA, CTA, CPI
(804 Views)
