12-20-2005 09:46 AM
12-21-2005 02:50 AM - edited 12-21-2005 02:50 AM
Message Edited by Ray Farmer on 12-21-2005 08:52 AM
12-21-2005 10:25 AM
| BOBY-L |
| NONE |
| Monday, December 12, 2005 |
| 4:16:19 PM |
| administrator |
| 37 |
| Failed |
Step | Sequence | Sequence File |
Numeric Limit Test: Receive 7 bytes | MainSequence | Read Test.seq |
SequenceCall | MainSequence | testing.seq |
Begin Sequence: MainSequence
(C:\VSS\Test Driver Code\Tests\Initializing Driver Test\Initializing Driver Test.seq)
SequenceCall Status: Passed
**********************LINK TO TEST****************
End Sequence: MainSequence
(C:\VSS\Test Driver Code\Tests\__TestStand - Common Components\common sequences\Read.seq)
Read 20 bytes Status: Passed Read the following bytes from Address 0000 of the FLASH:
46 00 C5 07 00 00 70 00 C3 03 00 00 9A 00 8D 04 00 00 E8 00
12-21-2005 04:06 PM
01-03-2006 11:04 AM
01-03-2006 04:01 PM
01-04-2006 10:50 AM
02-15-2010 03:50 PM
02-17-2010 02:01 PM
Hi all,
I do have a similar type of requirement where I need to create a new report for a particular sub sequence only.
I use xml report generation and teststand 4.2. I took some of the ideas suggested by Andrew.
So what I did was, I used a callback "testreport" and in that I ran a loop to check in the result list if it " contains any sequence call and sequence name matches with the name I am looking into" , if it matches I copied the result list of that sequence call into a local variable.
Till here it works good. Now I need to make a new report for this result list. This is where I am struck in generating a new xml file.
I used "testreport" callback because it runs at the end of the sequence where I can have the whole result list and make sub report for every sub sequence call to that particular sequence is made.
I went through the reportgen_xml.seq, it was difficult for me to understand, is there some tips or areas which I can concentrate on instead of whole *xml.seq which I can copy and generate a new report for subsequence.
I have another idea of moving this all result list data to labview and create a xml over there instead of in teststand.
Can any one please guide me.
Surya.
02-25-2010 08:51 AM
I got a solution for my query through NI:
"I do 2 Sequence Call steps in my MainSequence and on each call I configured the Execution Options to "Use New Execution". I then selected the Sequence Call Advanced Settings button just to the right of this field and changed the Wait for Execution to Complete field to "Before Executing Next Step".
This essentially forces the steps to stay sequential even though they are running in their own executions. "
Thanks to NI support.
