01-28-2025 05:03 AM
I try to return a long value from a method in a .net Adapter and try to give it a TestStand Number variable. I get the following error message in the step Settings: "Expected Number {Signed 64-bit Integer}, found Number {64-bit Floating point}"
Can you help me?
Best Regards!
01-28-2025 05:43 AM
You might wanna try to change the variable properties
01-28-2025 05:57 AM
Thanks for your help. Your suggestion solved my problem!
