Scripts are usually safe popup when opening XML reports
Whenever I open an XML report generated by TestStand internet explorer throws me two popups. This happens for all the individual logfiles and frankly its quite annoying, so I'd like to get rid of it. I've googled this subject and found two tips:
1. Enable "Active scripting" in the internet security settings
2. Disable "Allow websites to prompt for information using scripted windows" in the internet security settings
Did both, no change. I know for sure that there is a fix as I have done it years ago, but cant recall.
Any ideas?
thx!
(2,280 Views)
Accepted by topic author 1984
This is IE thing right?
If I remember correctly, options -> advanced -> allow active content to run in files on my computer.
(2,250 Views)
Exactly what I was looking for, thanks. BTW is it possible to open these logs in Chrome / FF etc? Looks like an odd limitation that it can be displayed only in IE.
(2,244 Views)
I have not found a way to open those reliably with another browser. XML format is not too good anyway (why is it even default format..) when you want to send these reports to someone else, since they would need stylesheets to correct path.
I would just configure results processing to HTML and no problems opening with whatever browser you want. Some features are lost though, but I would still prefer this in case you are not doing any data handling with those XML files.
(2,239 Views)
Yeah, I dont use XML either, it just that I have to work with a legacy station. Thx for your help.
(2,230 Views)
Hi 1984
Maybe this thread will help you to deal with IE in the future:
https://forums.ni.com/t5/NI-TestStand/Report-options-with-IE-11-retirement/td-p/4230346
Best Regards
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(2,222 Views)
