05-02-2013 04:00 AM
I'm using the latest version of TestStand and have created plenty of test solutions and deployments in the past, using the sequential model.
But this time, I'm using the BATCH model, and I just can't figure out how to include this setting in the deployment.
I've tried the following:
Would appreciate any help/advice
05-02-2013 06:33 AM
This information is stored in :
C:\ProgramData\National Instruments\TestStand 2012\Cfg\TestExec.ini
Under
[config]
StationModelPath2 = "BatchModel.seq"
You can write a simple exe which will modify this ini file.
Add this to the custom command list of the deployment.( check custom command button in the deployment -->Installer options).
Or
YOu can make all your test sequence settings to use batch process model.
Edit menu --> sequence file properties-->Advanced tab -->model options-->require specific model.
Overwriting the testexec.ini file is not good as it may already have some settings which may be overwritten.
Editing it should work.
06-22-2017 08:17 AM
EVEN MORE IMPORTANT! ensure in your Deployment Utility settings, within the Drivers and components settings in Additional components for Full Deployment to ensure the TestStand Runtime AND the Process Model runtime are selected! this burned me for 2 weeks.
03-02-2022 03:11 AM
I know its old thread, but still.
As brett has written:
I had a similar problem: in tester there was visible only Run Sequence button. After checking the TestStand XXXX Process Models Runtime in the Drivers and Components of Installer options in TestStand Deployment Utility, I see all 3 buttons: Test Sequence, Test UUTs & Single Pass.
With kind regards
Michal
