02-13-2010 11:14 PM
in Teststand 4.2 stationglobal.ini file has corrupted
how can i get new ini file
02-14-2010 11:10 AM
If you just want to start over again with a clean verison of the station globals file, just delete or rename it. TestStand will recreate this file at startup if it does not exist.
If you would like for us to investigate how the file got corrupted, please provide the file and as much information as possible for everything that was done right before it got into this state.
Hope this helps,
-Doug
02-14-2010 10:17 PM
hi
now new stationglobals.ini has been generated and we are getting error. that error has attached here.
02-15-2010 12:52 AM
That is because you now have a default StationGlobals and TSVP is not a default StationGlobals.
You will need to add this and another StationGlobals that you system needs which isn't part of the default file.
Ray Farmer
