NI TestStand
[TestStand 2012] Create a custom step type without step in possibility
I would like to create a custom step type based on the sequence adapter.
In my step type there two 2 steps.
I would like that teststand understand this not as a sequence but as a single step (prevent the user from doing step-in, for example)
Currently, in step-by-step, when I debug my sequence with F8 (step-in), teststand enter into the step type.
Do you have an idea or an example ?
Thank you
xpowaaa
(3,168 Views)
Sorry for the double post,
nobody have a solution ?
(3,102 Views)
If I understand your question, you would like to create a custom sequence call step where the "Sequence Call Trace Setting" is always "Disable tracing in sequence".
One way would be to make a default expression in the Pre-Expression: "Step.Module.AsSequenceCallModule.TraceSetting = SeqCallTrace_Disable"
This could also be implemented in "Substeps" as a "Pre-Step" and then you can implement that expression in your diesired programming language.
Pulido Technologies LLC
(3,093 Views)
Hi 🙂
Thank you for your answer
Sorry if I have not correctly expressed my question
I would like to prevent the "step into". If I force the "disable tracing" the user can still enter the sequence if he does a "step into" (F8).
Basically, I want to create a step that contains several actions but is done in one block.
Thank you again 🙂
(3,086 Views)
Hmm.  I don't think that can be done.
Would it help if the sequences to be called are in a password protected sequence (not viewable)?
http://digital.ni.com/public.nsf/allkb/5BC5346AF208C172862575A0007986E2
(3,076 Views)
I am guessing your sub sequence contains two action steps to code modules. If that is the case, you could use two post sub-steps to get the job done. As below.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(3,069 Views)
