NI TestStand
Unable to Launch 'LabView.Application'
When I start teststand and load a vi, then teststand is not able to execute te vi.
Teststand notifies me that it is unable to load the 'labview.application'.
When I manually load labview  then the problem is gone.
Somehow teststand is unable to load the development adapter, which is set ok.
(2,714 Views)
Hello there,
1) What version of Teststand are you using?
2) What version of LabVIEW are using?
3) Was this issue always the case, or did it occur after an event? (update, new install)
4) Have you checked the LabVIEW adaptor configuration is on the LABVIEW development system server.
Configure -> Adapters -> configure...
5) In LabVIEW check in Options -> VI server and make sure TCP/IP and Active X are
selected.
6) Could you try to add the LV15 directory to the directory configuration.
Configure -> Search Directories -> add LV15 directory
7) Have you tried reinstalling LabVIEW and Teststand and seeing if the issue persists?
Sas
(2,664 Views)
Hello Sas,
I use teststand and labview version 2014.
Adapter settings are set op 'use active labview Version: 2014 SP1 f7 (14.0.1)(32-bit)[Default]'.
This only happens when a certain person login, he first used the evaluation.
I will try the options you mentioned if my colleague arrives.
Thanks for the information so far...
Bart
(2,654 Views)
Today I started the PC again with the account from the production employee.
Now there are no problems...
It's very strange why this happened, I think it had something to do with the license.
The problem happened on the first day the license was activated, it was a computer based license.
Still thans for the help.
(2,628 Views)
