NI TestStand
TestStand File Diff/Merge
My XML file will not display in my web browser (Chrome, Firefox, or Edge).  it appear that the style sheet is blocked by the security setting on the browser.  The XML would display in the old IE.  Is there a fix or work around for this problem?
(913 Views)
Are you refering to the report generateg by the Diff/Merge Tool?
My guess is, that your company IT has set some  security features for yout browser, which prevent scripts from being executed (which is reasonable by the way 😉 )
(886 Views)
You can try to view the report using the XML report Viewer from the link below. Please post if the viewer does not work for you.
TestStand ATML and XML Report Viewer Support After Internet Explorer Retirement - NI
Anand Jain
NI
(878 Views)
