09-08-2011 03:57 AM
I am deleloping a test with TestStand 2010. I have protected sequence file changes from test users by setting a password for administrator, which I have now ... forgot (yes, I know, that is stupid!). I thought I had saved it in my password database (keePass2) but obviously I was mistaken.
I thought that by uninstalling TestStand and re-installing it I would have had the chance of resetting the user information, but I was mistaken there too ...
How can I rescue my TestStand development? Should I uninstall all NI s/w development suite?, cleanup the registry?
Any help very appreciated.
Marco
09-08-2011 06:10 AM
Try renaming the User.ini file in the CFG folder, then launching TestStand SeqEditor. There should be a new User.ini file created with the default settings. ie Administrator without any password.
09-08-2011 06:19 AM
Thanks very much! That solved th problem.
Marco
01-14-2025 01:33 AM
I have a similar issue. I have deleted the user in CFG but after restart back seq editor and trying to skip step its say password protected.
01-14-2025 01:41 AM - edited 01-14-2025 01:41 AM
What is the user logged in to TestStand?
01-14-2025 01:42 AM - edited 01-14-2025 01:45 AM
Admin
01-14-2025 01:53 AM - edited 01-14-2025 01:53 AM
Admin is no default account. So ther could be different privileges assigned which could cause this issue
Misread, sorry
01-14-2025 01:59 AM
Your issue is not rooted in the user privileges but in the fact that somene has locked the SeqeunceFile using a password
