05-04-2022 06:37 AM
Good morning TestStand experts,
I am facing the situation that I am executing a historically grown sequence, that itself calls a lot of sub-sequences, with each sub-sequnce implementing a lot of steps.
With a new SUT I am seeing the parent sequence failing, even though all sub-sequences and individual steps are passing.
Can someone give me a hint on how to find out, which step is causing the parent sequence to fail? I was thinking that probably there is a step, which has the "Step Failure Causes Sequence Failure" flag set to true in the "Step Settings -> Properties -> Run Options" while it has the "Result Recording Option" set to "Disabled". A first test showed that this is possible, but how would I find out, which step is causing the issue?
Thank you so much in advance
-Michael
Solved! Go to Solution.
05-05-2022 01:08 PM - edited 05-05-2022 01:08 PM
Hi Michael,
Have you tried to enable option "Break on Step Failure" in "Execute" menu?
05-05-2022 11:39 PM
Thank you Matheusz.
05-07-2022 06:51 AM
You're welcome, glad I could help! 🙂
