NI TestStand
Transfer data from DoPreUUT to main Sequence
Hi All, I am working on Modifying existing Sequential Model in NI TestStand.
In Do PreUUT i just wanted to have mu own Custom VI which will ask for a path and once the path is selected, the VI will Extract 2D Array of  String Values which i need to pass to my Main Sequence.I am facing Issue in tranferring the 2D array data From doPreUUT to mu main sequence.
http://forums.ni.com/t5/NI-TestStand/Pass-Parameters-from-PreUUT-to-main-Seq/m-p/2850684#
which says best way is to use file globals, but i am not able to get my values transfered to my main sequence.
Need help to resolve....
Thanks in advance
(4,320 Views)
Accepted by topic author PalanivelThiruvenkadam
if you are adding a FileGlobal to Test UUTs and expecting to access that variable in your client sequence file you will not be able to read the FileGlobal directly. You will have to use the string 'RunState.Root.FileGlobals.....'
eg if you have a string array FileGlobals.MyDataPaths, then in you MainSequence you could access MyDataPaths using RunState.Root.FileGlobals.MyDataPaths.
Remember that this will only be available when using the Process Model therefore you would be wise to test that you are running with the process model.
Hope this helps
(4,305 Views)
@ RayMond
Thanks for the reply and the advice on how to proceed.
(4,300 Views)
