NI TestStand
display one sequence at debug
I have a standard test stand solution like most of yours, a main sequence and many of sub-sequence.
When run single pass in debug mode. the 'single pass' window will show the current sequence or sub-sequence.
My question is I don't care the progress of sub-sequence, I care only the main sequence.
So any way to fix display only the main sequence in that window?
Thank you!
version: TestStand 2014 32bit
(3,739 Views)
Accepted by topic author NemoChen
Hello!
I think disabling tracing may help 🙂
I don't have TestStand in front of my eyes but as far as I remember:
  • select any subsequence (or all of them)
  • on the bottom of the window go to step settings
  • change tracing to: Disable tracing
If you change it your cursor will stay in main sequence.
Let me know if this helped!
mtwar
Think Dataflow - blog.mtapp.tech
(3,717 Views)
As suggested by mtwar, Disable Tracing the Possible option, but if you have a sub sequence which executes for a longer time then it seems like it hanged some where as the user wont be getting any feedback or response still the sub sequence completes its execution.
(3,701 Views)
Yes, it is excetly what I'm looking for.
thank you!
(3,636 Views)
