02-22-2024 10:36 AM
I am running into an issue after a fresh install. The install was pushed through System Link.
The error is fixed if I run TestStand in Admin mode or in Runtime, but I do have the development license so should be able to run in dev.
I have tried, doing a repair and re-installing everything, no fix. I feel like I am missing something simple.
LV2021 SP1
TestStand 2021 SP1
Thanks.
02-22-2024 02:00 PM
Can you try to launch LV as a non-admin user and then check if you still get the error?
When LV is launched as non-admin user, it adds the required registry keys so that TS can use LV's COM interface.
Anand Jain
NI
02-22-2024 03:37 PM
The licenses are assigned to the user and all the users that have the licenses are also admins on the PC.
so I can login with a non admin user but they don’t have the necessary licenses to run LV.
