02-06-2018 04:12 PM
I am getting an error when initializing veristand 2017 from Teststand 2016 (32 bit). Attached is a screenshot of the error. Please advice. All required patches have been installed on both systems.
02-07-2018 09:29 AM
Hi Sivan,
Interesting - it looks like you're using the VeriStand steps for TestStand and the initialization step. I ran through this with the same versions (TestStand 2016 and VeriStand 2017) and got it to work for me deploying the Engine Demo project.
Based on the error message, it looks like TestStand can't find the project you're referencing. Within the initialization step, can click the "Configure Gateway" button and make sure that the project path you're referencing is valid?
Also, support for the add-on is officially handled here: VeriStand Steps for TestStand Feedback, so I would suggest moving your question there as you'll find better support.
Otherwise, make sure you have the right versions of the steps installed as that could be a cause of the error.
