NI TestStand
Unload Modules to use 2 Dlls with the same name
Hello everyone.
I am currently using TS 2023, I have a sequence that executes a BounderyScan with XJTAG.
So I just starts the execution of the test by just execution a function in the DLL(.NET), The problem is that I have 2 version of the software V3 and V11.
I need to choose based on the DUT model so, and it gives me an error every time I change from one model to the other.
I tried using the UnloadAllModules function but as the RootClass have the same name it does not works.
I try with using UnloadAllModules and if the RootClass is different it works but in this case as is a Software of XJTAG and the DLL is from the own program I cannot change that.
I also tried to use the "Load Dynamic" options and more but it doesn´t works.
So, Is there a way to Unload the RootClass or clean that?
The goal is to be able to use 2 dll with same name and the same RootClass
Currently the only way to change between one DLL and other is stopping the sequence and Run again
Message 1 of 1
(22 Views)
