Using string functions to parse GNSS sentences
Can someone help with TS string functions?
My goal is to extract the first line starting with "$GPGGA", and then separate it into an array separating at the commas.
Sample input:
$GPGGA,211332.000,4202.4046,N,08802.0322,W,1,8,0.98,274.2,M,-34.1,M,,*6C
$PGTOP,3,AXN_3.20,8175,007-21-2014,GNSS_EXTRF_9600,007-05-2014,211333*03
$GPGGA,211333.000,4202.4046,N,08802.0322,W,1,8,0.98,274.2,M,-34.1,M,,*6D
$GPGGA,211334.000,4202.4046,N,08802.0322,W,1,8,0.98,274.2,M,-34.1,M,,*6A
$GNGSA,A,3,19,28,25,10,,,,,,,,,1.54,0.98,1.19*10
Is the "$" character special in TestStand?
FWIW in python I'd do
s.split('$GPGGA')[1].strip().split(',')
(2,927 Views)
Accepted by topic author stephenb2
Hi Stephen,
Have you seen this?
Parsing a String Using Functions from the TestStand Expression Browser
http://www.ni.com/example/26308/en/
This seems to be similar to your goal.
Chase
NI Technical Support Engineer
(2,891 Views)
Thanks, that was very helpful. Especially the combination of "Find" and "Replace".
1. search for position
Locals.position = Find( Locals.my_string, Locals.search_string )
2. Remove everything before find by replacing with empty string
Replace( Locals.my_string, 0, Locals.position, "" )
3. Repeat as needed
(2,887 Views)
