api dll windows 10 teststand 2014 SP1
I'm searching a fix to my issue since few hours but I found nothing. I'm working on Teststand 2014 SP1 32bits with a windows 10.
I made a sequence on the same version of teststand on a windows 7 but I now have a windows 10. I openned my sequence (which worked well on W7) on W10 but when i'm exécuting it I have the following message.
http://puu.sh/pizsw/deabdd594d.png
I tried to install the W10 SDK, and some versions of Visual studio but didn't work. On my 64 bit version i have an other message which seems normal cause it says TS is unable to open my 32 bits DLLs.
I think i forgot to install something but I don't find what, if soemone found a solution at this problem, should be great to share 😃
Guillaume
(4,293 Views)
Accepted by Guillaume73
It would be wise for you to recompile DLL-07_modbus.dll to work on Windows 10.  It looks like all of its dependencies are specific to W7.
jigg
CTA, CLA
testeract.com
(4,266 Views)
Or at least the relative paths to the system DLLs is incorrect.  I'm not familiar with the folder structure in W10.  So where are these DLLs located on W10 relative to W7?
jigg
CTA, CLA
testeract.com
(4,265 Views)
Hi jiggawax,
I'm using a relative path so it should be a problem, TS is finding the DDLs. The DLLs version should be the problem i guess because they are made by LabWindows which isn't compatible with W10 yet. Do you think that can be the origin of my issue ? When LabWindows will be compatible with W10 ?
Thank you.
Guillaume
(4,253 Views)
This should help you understand when it will support W10:
http://www.ni.com/white-paper/52818/en/
jigg
CTA, CLA
testeract.com
(4,231 Views)
Thank you to your help, really helped me.
Guillaume
(4,220 Views)
