Normally you use the "?:" conditional syntax as follows:
Locals.Number = (Locals.Boolean)? 10 : 5
Also, if you want multiple assignments you can separate them with a comma such as
Locals.Number1 = 1,
Locals.Number2 = 2,
Locals.Number3 = 3
So you could combine these two as follows:
(Locals.Boolean)
Locals.String = "True",
Locals.Number = 9
: Nothing
What is really happening is:
if the boolean is true, the last assigment object is returned "Locals.Number".
if the boolean is false, the conditional returns the null object reference.
Since you are not using the returned value from the conditional, it is just dropped and ignored
Scott Richardson (NI)
Scott Richardson
https://testeract.com
