NI TestStand
get station model
Dear All,
I'm using c# user interface example and I would like to know what kind of station model and how many stations the sequence is configured.(before executing the sequence)
How can I get the type of station model (batch\sequential) and No. of stations with the relevant objects (axApplicationMgr\axSequenceViewMgr\axExecutionViewMgr)
Tnx
(4,124 Views)
You could use: Engine.StationOptions.StationModelSequenceFilePath
to determine which ModelFile is used.
and if your SequenceFile is refering to the model: SequenceFile.Model
is pointing to the model.
Maybe this helps
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(4,117 Views)
Accepted by NewSCRUser
Hi Juergen,
Thank you for quick and helpful answer
private void axApplicationMgr_DisplaySequenceFile(object sender, NationalInstruments.TestStand.Interop.UI.Ax._ApplicationMgrEvents_DisplaySequenceFileEvent e)
            string t = string.Empty;
            e.file.GetModelSequenceFile(out t);
(4,115 Views)
