hiding steps at runtime
I have a subsequence that I point the user to when they are asked to isolate a board failure.  To provide them with some flexibility, I have a popup that gives them a number of opetions (see attachment).  I have a test procedure that instructs them to select/run individual steps (i.e. '1' or '3' in the png).  The flow control (denoted by '2') is noise they don't really need to worry about, and may/will cause confusion (and possibly problems for me if they select them accidentally).  Is there a way to hide these Flow Control steps during runtime so that the user only sees '1' and '2' (and the other similar 'valid' selections?
(4,522 Views)
Do you want to hide or disable the steps during run time?
(4,515 Views)
I just want to hide the flow control (if possible) so the user has less clutter through which to filter
(4,512 Views)
Put it all in a subsequence and disable tracing into the sequence call.
jigg
CTA, CLA
testeract.com
(4,507 Views)
I thought of that, but once I move the select statement (and the associated case statements) into a subsequence file, I lose scope, and the Select and Goto statements no longer have visibility into the labels found in the parent subsequence (i.e. MR_RPack_R55).
(4,504 Views)
You could use a subsequence to evaluate the result of the Message Popup ButtonHit,
By passing in the Result.ButtonHit and the subsequence shall return the unique step id for the appropriate step -
The subsequence would use the select/case structure to set Locals.NextStepUniqueId:
The top-level sequence could then call the returned step id as a post-action to the subsequence:
(SequenceFile attached).
Charlie
Charlie Rodway | Principal Software Engineer | Certified TestStand Architect (CTA)
Computer Controlled Solutions Ltd | NI Silver Alliance Partner | GDevCon#1 Sponsor
(4,476 Views)
Accepted by mrbean
If there wasn't an explicit need to have the logic as flow control, then I'd be tempted to compact it all into the post-action of the Message Popup;
By setting the Message Popup Post Action to Goto Step, <Specify by Expression>, Use Custom Condition (TRUE):
And using the following Expression:
Step.Result.ButtonHit == 1 ? RunState.Sequence.Main["MR_RPack_R55"].UniqueStepId :
Step.Result.ButtonHit == 2 ? RunState.Sequence.Main["End_PCI_Isolation"].UniqueStepId :
Step.Result.ButtonHit == 3 ? RunState.Sequence.Main["MR_R103"].UniqueStepId :
Step.Result.ButtonHit == 4 ? RunState.Sequence.Main["PCI_Intf_PT"].UniqueStepId : ""
This should goto the appropriate step following the Message Popup.
I hope this helps.
Charlie
(4,475 Views)
