NI TestStand
how to change a step name in subsequence
i am using the below statement to change the step name in subsequence. under pre expressions :
Step.name = RunState.SequenceFile.Data.Seq["MainSequence"].Main[Step.UniqueStepId].name + " [Channel: " + Locals.currentChannel + " | Iteration:" + Str(Locals.i) + "]"
I can able to execute the abouve statement in main sequence but not in subsequence. does anyone know how to change the step name of subsequence programmatically.
swathi kamble
(3,073 Views)
Locals of Main sequence cannot be used in Sub Sequence (Local Variables are used within a sequence not between sequences.make sure you are suing parameters if you need to share data between Sequences.
(3,024 Views)
Hello, Thanks for the reply. I used the file global to pass data between the sequence but still i am getting the error ( refer to the attached screen shot).
(3,018 Views)
Hello Swasa
If Possible Share the Sequence Which you have created.so that we can view and suggest you the right approach.
(3,002 Views)
In the main sequence i am calling call 4 up sub sequence, attached screenshot, In cal 4up seq on the 1 st step, i wanted to change the step name based on the for loop.
(2,991 Views)
Accepted by swasa
Step.Name = RunState.SequenceFile.Data.Seq[RunState.Sequence.Name].Main[Step.UniqueStepId].Name + " [Channel: " + FileGlobals.currentChannel + " | Iteration:" + Str(FileGlobals.i) + "]"
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,981 Views)
Thank you!! It worked 🙂
(2,963 Views)
