The Step parameters is missing in this report. Is there a way to add this just as you have included the Sequence parameters. Thanks.
Sequence: MainSequence
Type: Normal
Disable Results for All Steps: False
Goto Cleanup on failure: Use Station Option
Number of Setup steps: 2
Number of Main steps: 10
Number of Cleanup steps: 2
Parameters:
PartNumber String (by reference)
Step: Setup Instruction
StepType, Adapter: Message Popup, <None>
Description: NameOf(Step)
Module Load and Unload Options: Preload when execution begins, Unload when sequence file is closed
Record Results: Disabled
Flow Properties: Post Action:
if ()
Goto <Cleanup>
Result Recording: Disabled
