NI TestStand
uint64 Numeric Limit Step
How do i use UInt64 in a numeric limit step.
TS says "expected Number found Number {UInt64}.
If i change the Numeric format for the limits to UInt, my limit values are modified. I can't select UInt64 as Numeric format. My DataSource format is UInt64.
br
Nikolaj
(4,551 Views)
It works if i convert my UInt64 to Float64...
is that really it ?
(4,550 Views)
is that really it ?
I would advise against doing that. Not all UInt64 values can be exactly represented in a Float64 so you will get some rounding error. It depends on what you are doing whether or not that would matter.
The numeric limit step does not currently support 64-bit integers, however the CheckLimits() expression function does support them so you could do something like:
Step.Result.Status = CheckLimits(Locals.Measured, Locals.High, Locals.Low, "GELE", False)
Also you might want to post a feature request to:
http://forums.ni.com/t5/NI-TestStand-Idea-Exchange/idb-p/teststandideas
Hope this helps,
-Doug
(4,494 Views)
