06-12-2016 02:18 AM
Hello All,
I am using LabVIEW 2012 and NI Teststand 2012. I have experenced many a times that when I want to unload the code modules . some times/ many a time test stand does not relase LabVIEW code modues .Teststand will be still holding the LabVIEW code modules.After performing many time of unliding the modules in teststand also code module does not get released .
please suggest me if there is any other way or method to release the code modules .
Prithviraj
06-13-2016 12:31 AM
@Padugur wrote:Hello All,
Prithviraj
Did you tried unload options in step settings properties? as attached
06-13-2016 03:21 AM
Hi ,
Thanks for replying , my sequence steps are set as per your suggestion .
my requrement is teststand doesnt not allow VI , to release . after unloding the modules in teststand.
Prithviraj
06-13-2016 05:07 AM
@Padugur wrote:Hi ,
Prithviraj
Not Releasing means, After completing the whole sequence or after executing that particular step?
whether your code module is one time run vi or looping ?
