NI VeriStand Add-Ons Discussions
Creating Custom Workspace Objects tutorial
In the "Creating Custom Workspace Objects for NI VeriStand" tutorial, it is said "The Gateway IP Address control is one of the optional inputs from NI VeriStand, and NI VeriStand populates this control with the IP address of the target controller."
Where can I find the list of all the optional inputs for custom workspace objects ?
Yohann L.
(5,918 Views)
Accepted by yledieu
There isn't a list but you can find the optional inputs for custom workspace objects in the Workspace Tool Example.vi found in <Program Files>/National Instruments/LabVIEW <version>/examples/NI VeriStand/Workspace directory. They will appear as named controls on the workspace. You can copy and paste these controls (do not change the type or name) into your workspace object. These controls will then be populated when run within the workspace context.
In the future we ask that you post generic VeriStand questions to the NI VeriStand Discussion Forum. This forum is meant for posts that are specific to the custom devices found on the VeriStand Add-Ons page.
Lynn
Senior Systems Engineer
(5,326 Views)
