05-09-2013 08:37 AM
Hey Rajamodol,
The error you are getting is actually a Veristand error(http://zone.ni.com/reference/en-XX/help/372846B-01/veristand/vs_error_codes/). I usually get this when VeriStand is not open. Is VeriStand fully started after the Start Veristand step? If not you might need to increase the time to wait in the properties of that step:
05-10-2013 12:53 AM
HI Kevin,
I have a problem with the Get Channel Value function. The config step has same page as the Set Channel Value and I do not know where the read value of the executed funktion stores.
I hope you can help me
Lucas
05-10-2013 03:18 AM
Hi Kevin,
I have set the delay as you mentioned to 30s, 60s, 90s,... 120s... I still get "error -307652; User-defined error code." ;(
And also, the red warning in "Analysis Results" is still there, even i already initialized the Start Veristand in post #47.
I am using :
NI Teststand 2012, NI Veristand 2012
Windows 7
Microsoft .NET Framework 4 Client Profile
Microsoft .NET Framework 4 Extended
Perhaps, reinstall teststand + veristand will help?
Rajamodol
05-10-2013 08:08 AM
Hey Lucas,
The channel value is stored in the results cluster of the step. You can access this at run time by looking at the run state of the sequence.
Rajamodol- definitely no need to reinstall. Those are the same set of products I use for my tests. What happens if you delete the start veristand step and just start veristand manually before running the rest of the sequnce. Can you post your sequence so I can test it out on my machine?
05-13-2013 04:02 AM
Hi Kevin,
thanks for your answer.
I have checked the variable at run-time. But the value was always zero even though the channel value was set to 1. I could also see that in the workspace.
Is it correct, that the Get & Set Channel have the same configurations page?
We found the problem,
after we removed the Evaluate expression by the neuVal (OutputVal), the funktion works.
Lucas
05-13-2013 08:32 AM
Hey Lucas,
You are right there is a bug there.
The error is that the new value parameter has an Evaluate() function call around the result. You can fix it as shown above or install the updated steps installer that I just posted.
Post back if you have any issues with that.
05-14-2013 07:22 AM
Hi Kevin,
Reinstall TS2012 + VS2012 doesn't help also... still have the same error.
Start Veristand step was also deleted.. Veristand was started manually, and i already waited untill ca. 2-3 mnt, then run my sequence.. same result. No chance.
Where shall i send you my sequence? Here i can only attach image and video.
Rajamodol
05-14-2013 08:47 AM
Hey Rajamodol,
From looking at the sequence you sent me I think what is going on is that you are using the target IP address as the gateway IP. What do you see if you provide localhost as the gatewayIP?
05-17-2013 05:47 AM
Hi Kevin,
You're right.... it works now...
Rajamodol
06-07-2013 02:44 AM
Hey Kevin,
thanks a lot for all the good information so far! I followed your instructions from the "NI VeriStand Add-on: Custom NI VeriStand Steps for NI TestStand"- sheet. I also want to configure a RT Sequence and tried to recreate your example. Now I think I´ve got a similar or the same problem as rajamodol but I coudn´t solve it. Why isn´t the "module"-button in the step settings pane displayed?
How can I get to the Module specifications?
I am using :
Windows 7
Hope you can help me!
Regards Michi
