NI VeriStand Add-Ons Discussions
NIVS 2011 - Help not available
Hi guys,
I just installed the 3.2 version on my windows 7 (64 Bits) machine.
I've a minor issue in a sense that Help cannot be loaded apparently for the CD.
I assumed the CD tries to load the file "Scan Engine.chm" from "data" sub-folder and I can't open either from Windows Explorer (same error message).
What do you suggest?
NOTES:
- I join a screenshot of my System-Explorer Window.
- when browsing outside from this CD, help is loaded and available.
Regards
Vincent
(5,011 Views)
It could be Windows UAC blocking access to the file.  From the NI VeriStand™ Execution API Documentation (where a similar problem can occur):
Tip: If you cannot view topics in the attached file after downloading the CHM, your Windows User Account Control (UAC) might be blocking files you download from the internet. To enable viewing, right-click the downloaded file and select Properties from the shortcut menu. On the General tab of the Properties dialog box, click the Unblock button.
(3,315 Views)
Hi Devin,
Thanks for prompt reply, good catch! I unblocked it and it works now.
Regards
Vincent
(3,315 Views)
No problem!  Glad that fixed it!
Unfortunately I don't know why that would show up on your computer but not on others.  I guess I should make sure the fix is documented in the readme.
(3,315 Views)
