03-25-2015 07:14 AM
03-25-2015 07:33 AM
03-25-2015 11:18 AM
Hi Vincent
Just looking at that now.
Any recommendations on good datatypes/values to use?
a veristand example with this implemented would be great !
Jonathan
03-25-2015 12:03 PM
Hey Jonathan,
You can send me a private message if you want.
BTW, you shoud be able to download the source as ZIP and rebuild it for your version.
The one available on GitHub is a Multi-Y. So as you noticed, it's a Multi-Plots BUT all Y vectors are relative to same X vector.
If you want to transform it to a Multi-XY, that's a good idea.
Vincent
03-27-2015 01:43 PM
So I don't know if this will help, but in 2008, I did some work with the INERTIA platform before it was integrated into VeriStand and I made an XY Graph vi. Maybe you could figure something from this.
https://www.dropbox.com/s/v0j0j93vkjexwj2/Graph%20-%20XY.vi?dl=0
01-03-2017 01:34 PM
Does anyone know how to use this custom control with newer versions of labview/veristand. I am using 2015 sp1 and I cant get it to open without errors
04-19-2017 05:56 AM
Hello tmar89,
I was trying to access the dropbox link you provided. It is unavailable. Do you still have the XY graph you spoke about?
