NI VeriStand Add-Ons Discussions
XY Graph in Veristand?
Hi
I am looking to implement a XY graph into Veristand. The documentation is limited & examples of custom workspace items aren't designed for graphing.
Any ideas/help would be appreciated.
Regards
Jonathan
(7,300 Views)
Hi Jonathan,
Have-you looked at?
https://github.com/NIVeriStandAdd-Ons/Multi-Y-Graph
Regards
Vincent
(5,956 Views)
Hi Vincent
Just looking at that now.
Any recommendations on good datatypes/values to use?
a veristand example with this implemented would be great !
Regards
Jonathan
(5,956 Views)
Hey Jonathan,
You can send me a private message if you want.
BTW, you shoud be able to download the source as ZIP and rebuild it for your version.
The one available on GitHub is a Multi-Y. So as you noticed, it's a Multi-Plots BUT all Y vectors are relative to same X vector.
If you want to transform it to a Multi-XY, that's a good idea.
Regards
Vincent
(5,956 Views)
So I don't know if this will help, but in 2008, I did some work with the INERTIA platform before it was integrated into VeriStand and I made an XY Graph vi. Maybe you could figure something from this.
https://www.dropbox.com/s/v0j0j93vkjexwj2/Graph%20-%20XY.vi?dl=0
(5,956 Views)
Does anyone know how to use this custom control with newer versions of labview/veristand.  I am using 2015 sp1 and I cant get it to open without errors
(5,870 Views)
Hello tmar89,
I was trying to access the dropbox link you provided. It is unavailable. Do you still have the XY graph you spoke about?
(5,628 Views)
