10-24-2013 04:18 AM
السلام عليكم
لدي جهاز cRIO9004
لا يظهر في MAX
هل من مساعدة ؟
10-24-2013 08:24 AM - edited 10-24-2013 08:25 AM
That's probably because there is a conflct with the firewall or an IP conflict between your PC and the cRIO. Make sure you disable the firewall first. If that doesn't work, reset the cRIO to reset the IP. There is a small Reset button on the cRIO that you need to press, then connect the cRIO to the PC and set the IP on the same subnet. Have a look at:
12-05-2013 02:00 PM
لمن يستعمخل لابفيو بالعربية
حماده بن ناصر
12-05-2013 02:02 PM
لمن يستعمل لابفيو بالعربية
د\حماده بن ناصر
12-05-2013 02:04 PM
12-05-2013 02:12 PM
د\حماده بن ناصر
12-05-2013 02:14 PM
د\حماده بن ناصر
