09-06-2010 04:13 AM
The installer which built in LabVIEW 8.6 is getting installed successfully in all PC's. But in some PC's, when I try to run the application It says "The VI is not executable. The full development version of the LabVIEW is required to fix the errors". I am unable to run the Executable. Is there any problem?
10-10-2012 12:59 AM
did you got the solution, i got same problem in labview2011.
02-02-2013 02:15 AM
Are you sure that all the file in the project is execuatable ?
What error number you are getting, Can you post your VI.
