11-26-2018 10:14 PM
I just bought the new kit and running the RT vi for 9636 showed connection error but MAX showed 9637 connected running via USB.
It IS very frustrated to connect via ethernet and this non sense jumping from 9636 to 9637 from NI support. It MUST update and verify ALL the example codes WORKING 100% before releasing
11-26-2018 11:44 PM
I am using sb9636, initially i also experienced same issues.
you have to update RT Runtime engine version of your board.
suppose if you are using labview 2016, same RT you have to update in SBrio board, you can to update using NI Max,
you may have to select additional installers if you want to use them, like for RS232 communication, Visa drivers etc.
A Anil
CLA
