03-22-2016 04:43 AM
I am using a chassis 9073,having 3 cards out of which one is 9237.
9237 was used as half bridge,now changed to full bridge.I wanna calibrate it.
I have a docu for it from the internet.In that it is mentioned that,i have to self test.
The chassis alone is listed in the Max,how can i self test this card??
Pls help.
03-22-2016 10:30 AM
Hi Krupa! You can self test your card in NI-MAX. Open NI-MAX, and then expand "My System" -> "Devices and Interfaces" and then select your card. You should find an option to self-test.
03-22-2016 01:28 PM
That is only true if you are using cDAQ. In this case krupa is using cRIO, which does not support Self-Test or Self-Calibration from MAX. I'm not 100% sure, but I think you may have to do it programmatically.
