PXI
Accessing PXI Analog input card over ethernet
Hello Guys,
I want to access PXIe-6363 channel remotely from LabVIEW.  I don't know how to access the DAQ channel because the PXI system is on network. Could you please help me? Thanks.
Message 1 of 9
(3,818 Views)
Hi Siva68, there is no easy way such as Test Panel. When you would like to read a value of channel on remote PXI DAQ,
you must develop real-time application.
Certified LabVIEW Developer
GCentral
Message 2 of 9
(3,680 Views)
Hello Emboar,
Yes, That's what I want to do. The problem is, I don't know how to reference the Daq channels (i.e ai0...ain) on our system. We use veristand but I am new to veristand and custom devices programming. The DAQ module shows up on VesiStand but I don't know how to use it.
I just want to try to read some values on the analog inputs channels with DAQmx VIs before I work on custom devices. Is there is a way to do it? Thanks.
Siva
Message 3 of 9
(3,621 Views)
From VeriStand? OK, it makes all simple.
On system definition file (SDF), you can add new DAQ hardware and channel as below.
GCentral
Message 4 of 9
(3,616 Views)
Hello Emboar,
That's ok already. How do I use it inside my LabVIEW VI? How do I program it/configure it inside VI? That's what I don't know. Thanks.
Siva
Message 5 of 9
(3,613 Views)
Do you want to read DAQ channel in custom device? Just use DAQmx.
GCentral
Message 6 of 9
(3,610 Views)
Hi Emboar,
If I knew, I wouldn't have posted this question eh? 😅
The channels or device is not showing up. Also I can't create anything new. Where am I making mistakes? Thanks.
Message 7 of 9
(3,606 Views)
Are you developing your application on PXI RT?
I don't have RT PXI at this moment so cannot confirm but if I remember correctly,
you can see your device developing on PXI RT.
GCentral
Message 8 of 9
(3,595 Views)
Hello Emboar,
Interesting. Yes, it is Ok with PXI RT. 😊
But not ok in the custome devices or normal project VIs. I tried use it the ip- address but something is wrong. Can't reference the channels.
Thanks and Regards,
Siva
Message 9 of 9
(3,585 Views)
