PXI
Any Way to Increase Input Impedance of PXI-4353?
I plugged one thermocouple into two instruments including PXI-4353. Since the input impedances of those two instruments are not high enough, neither read a correct temperature. Is there any way that I can increase the input impedance of PXI-4353?
FYI, my current solution is to add a buffer between the thermocouple and the other instrument but I'd like to eliminate that if possible.
Max
Message 1 of 1
(852 Views)
