07-16-2022 12:39 PM
I want to measure voltage-drop over a shunt to calculate the current. The measured Signal is in a range of 0-100 mV. We have an PXI module 4330 used for bridge measurement. Is there a way to use this module for this problem?
maybe i can just use AI+ and AI- to measure voltage drop and just dont use the exication voltage and set it internal on some value to calculate the voltage. Any idea what i can do would be helpful.
11-29-2022 04:43 AM
Does someone has a solution for this? I have the same issue
