PXI
PXI-6040E Calibration Procedure
I am setting up a new calibration procedure document for a PXI-6040E in our Calibration Lab system.  I need to have a document that indicates the procedure per NI.  What document should I use? I found E/S/M/B Series Calibration Procedure for NI-DAQmx, would this be correct?
(128 Views)
Accepted by topic author TomPic
I assume you are referring to the external calibration. See Can I Perform an External Calibration for my DAQ Device in LabVIEW?
(100 Views)
Yes, thanks for the confirmation!
(96 Views)
