PXI
PXI 6528 Custom Input Interface
I am trying to find a solution to go from the 6528 input/output into flying leads. Is there any market solution that goes from the input interface to flying leads? I don't want to use the tiny metal block. I know if I just chop one end off, itll be a bunch of tiny wires that are hard to re-wire and such.
Any info or direction would be appreciated
(2,178 Views)
Following breakout boards are supported for 6528 instrument but not a flying lead cable
http://www.ni.com/product-documentation/53085/en/
Santhosh
Soliton Technologies
(1,848 Views)
So I am trying to put it into a rack and having the tiny box makes it hard to interface with. Is there a way to avoid being constrained to NI proprietary products are being more towards open?
Is the R1005050 ribbon cable a standard ribbon cable breakout or another NI property that requires the CB-50LP?
Thanks for the info so far!
(1,761 Views)
