PXI
PXI CPU Core Usage – Only One Core Shown Despite 4 Cores Detected
I have a PXI system that detects 4 CPU cores, but only one core’s data is visible on the screen. Even with a simple VI running a basic while loop, CPU usage shows 100%.
Has anyone experienced this issue or know potential causes? Any guidance on resolving this would be appreciated.
Thanks!
(196 Views)
Put four independent while loops, and you will see the usage on multiple cores (don't highlight execution).
Santhosh
Soliton Technologies
(181 Views)
Thanks but the problem is even more complex vi’s, there is only one cpu is shown and total load is %100. İ tried 4 parallel while loops and problem is still same. But it also says “Labview Real-Time Single-Core Kernel found 4 CPU cores”
(166 Views)
Is this with PharLap or Linux RT? If with PharLap, make sure to have "NI RT Extensions for SMP" installed in the software list for that PXI.
Hope this helps!
(110 Views)
