PXI
PXI5152 Aquire a repeating signal in python - get waveform data into an array and display array
Hello everyone,
    A Duquesne University graduate student is researching detecting cancer and I've been tasked with helping her capture using a PXI-5152   Acquisition board in a PXIe-1073 Chassis connected to a windows 11 PC via a PXI  using Python. The device shows up as ("PXI8::15::INSTR",) but I am not able to use any sample Python code to open the device and acquire a waveform from it.
   It seems likely that someone has already created an example that we could start from or has advice where to start. Questions I have are:
  + Where is the reference manual for the PXI5152 to know what commands I can send to it via python - commands such as x.setSomeValueXAxis("5mv")   I have seen x in previous be something like scope.setSomeValueXAxis("5mv");
  + Examples that might work off the shelf with our board the PXI5152 so we know the tool chain CAN access the digitizer/scope. At this point NI Max shows the chassis, the aquisition/scope card and can launch a gui tool that shows waveforms from the card (Ni Scope - but the new one Instrument Composer or something like that).
Thank you
Richard Newman
Assisting Duquesne University
Pittsburgh PA USA
(629 Views)
Your device is not being recognized correctly by NI MAX. Make sure you have installed NI-SCOPE driver (21.5 or later since you are using Win11). If you have installed the driver, there is a possibility that your MXI system is not enumerating the module correctly, since you are using PXIe-1073, an MXI chassis. See MXI-Express Compatibility and Connectivity Troubleshooting Guide.
Once your PXI-5152 is recognized correctly, you can go ahead and use niscope · PyPI
Control Lead | Intelline Inc
(623 Views)
