PXI
PXIe-1090 SMBus Controller driver error code 10
I have a PXIe-1090 with a PXI-4461 and PXIe-6341 installed. My computer is not recognizing the PXIe-1090. There are two errors in the device manager. If I only plug 1 thunderbolt cable in, the error in the USB 3.1 device goes away.
I've tried disabling Kernel DMA Protection in the bios, but that didn't help. Any ideas?
(1,429 Views)
Are you sure your computer has a Thunderbolt3 port? and you're plugging into a Thunderbolt 3 port and not a USB3 port?
Santhosh
Soliton Technologies
(1,422 Views)
yes it is a thunderbolt 4 port
(1,416 Views)
Update:
It appears to have something to do with the 4461.
If I have the chassis and the  6341, everything works (only if 1 cable is plugged in)
If I plug in the 4461 I get the driver error on the SMBus Controller. Also, I have two 4461 cards and it does this with both.
(1,403 Views)
Oh, I don't think the DSA cards are supported on a 1090
Santhosh
(1,377 Views)
Hi, I have a PXIe 4464 card in a PXIe1090. I wanted to know whether 1090 will work with thunderbolt 4??. Supplier is suggesting me to get a thunderbolt 3 but thunderbolt 3 devices are not available and we already have a thunderbolt 4 computer.
(1,041 Views)
