PXI
PXIe-8381 connection problem
HI,
I use a PXIe-8381 module to connect the PXIe-1082 chassis through a Linux PC. I installed NILinux2023Q2DeviceDrivers on AlmaLinux 9.1 (binary compatible to RHEL9).
The whole development setup works fine and I can develop software using nidaqmx successfully.
But when I carried my PC and tested the software on another testbench chassis, I found that I fail to connect. The front panel LED of the PXIe-8381 module which is inside the testbench chassis was always solid amber.
I was quite confused. The part number of PCIe-8381 is the same (153097C-01L), why one module worked while another did not?
If I switch the PXIe-8381 module from the testbench chassis to my development chassis, the problem still exists. So I guess the problem source is the PXIe-8381, but what should I do to fix it?
The PC motherboard is ASUS Prime Z270-A, BIOS is updated to the latest one.
The Bus Number Range checked by  MXIeBusDetect.exe is  [0, fe].
The MXI-Express BIOS Compatibility software does not support Linux. I did not try it.
Thanks in advance for your help.
(888 Views)
Hi Stopper3046,
That's a tricky problem. The short answer is "RMA it" -- NI can figure out what's wrong.
It's probably out of warranty, though, so here are a couple things you could look at:
  • compare the two boards, look for damaged/missing components (it happens)
  • verify the LEDs on the card are active (there's are some "breathing" LEDs when in a chassis)
  • swap cables if you have a 2nd one
  • look for bent backplane pins (they're fairly easy to spot)
The LED is amber which means the power rails are good, and dragging your PC over eliminates a bunch of possibilities. Most of the debugging LEDs (on the board inside the chassis) have meaning, so if you spot a difference when plugged into the PC (and powered) it could be helpful.
- Robert
(808 Views)
