PXI
SHC68-68-EPM (P/N: 192061-02) Installation Manual
I want to locate the installation instructions for SHC68-68-EPM (P/N: 192061-02) multi-functional cable to identify the recommended torque value should be applied to mate the 68-Pin VHDCI Male and 68-Pin D-SUB Female connector thumbscrews/jackscrews. Thank you!
I was unable to locate it on the product page (SHC68-68-EPM - NI).
(95 Views)
Accepted by topic author TonyWong
Unlike RF connectors, there is no strict torque requirement that impacts signal integrity but rather it is to ensure mechanical connection without causing a mechanical failure.
Typically, just finger tightness with a screw driver (holding the screwdriver using two-three fingers and not the palm and all fingers).
Santhosh
Soliton Technologies
(81 Views)
Thank you, Santo!
(63 Views)
