03-16-2016 01:43 PM
March 16, 2016
The master library of examples and IP has just been updated. The download link is the same. The old version is archived here.
The new version includes:
We hope you will help us test and improve the new IP cores and examples, and their documentation.
Note that the Real-Time processor portion of the GPIC Reference Design Code for sbRIO-9607 GPIC is currently under development.
07-25-2016 11:24 AM
I am trying to downconvert this code(specifically the GPIC project) into LabVIEW 2012 version but I am hitting a lot of roadblocks(VI missing, bitfile missing and password protected StarSim VIs).
Is there a way in which I can compile this code and use it in LabVIEW 2012?
Thanks.
07-27-2016 03:32 AM
Hello sir,
First thanks for sharing this material! Now I'm doing somthing about FPGA-based Real-Time Hardware-in-the-Loop Simulation and Rapid Prototyping of Power Electronics,so I used this example to learn how to build a complete project and a project how to work .but when I tried to workout this coding it couldn't work and showd many errors. Could you plesae tell me where I can find this complete code or send this coding to wcq214212@163.com.I will very appreciate it.
Thanks for your reference!
08-01-2016 08:18 PM
Hi BMac,
My project is for controlling of three phase NPC multilevel grid connected inverter, so could you please give me piece of advice about the minimum of The Third-Party Add-Ons which are necessary for my project. Do I really need to buy the StarSim Control IP Toolkit? Could I create that project by using only resources from NI for GPIC 9606?
Thank you very much!
08-02-2016 06:43 AM
Hi BMac,
When I make a Half-Bridge Buck-Boost circuit in Multisim, I could not find components named: VARICOIL and R_LESR VARIRES as shown in this figure below
This figure is from the example project "GPICBuckBoost2014". Could you please tell me how to create that kind of component in Multisim.
08-08-2016 10:47 AM
In Multisim, you can find versions of the variable (voltage controlled) inductor, capacitor, resistor components in two different places.
1. Right-click on a blank area of the circuit schematic and go to Place Component. Then navigate to Power>BASSO_SMPS_AUXILIARY>VARICOIL.
2. Or navigate to BASIC>BASIC VIRTUAL>VOLTAGE_CONTROLLED_INDUCTOR_VIRTUAL.
3. Also, keep in mind that there is a component search function.
08-09-2016 09:05 AM
Hi!
Now I'm doing a real-time simulation of single-phase inverter project, I want to konw if I can complete this project only with NI-PXI and some softwares(labview,multisim).If can,Could you give me some suggestion about how to do with it? If can't,Could you tell what kind of software and hardware I need and suggest a way to do a real-time simulation of single-phase inverter ?
Thanks!
08-09-2016 06:02 PM
Thanks BMac! I got all of them for my own circuit.
08-10-2016 04:47 PM
Regarding real-time simulation of a single-phase inverter, there are a number of choices available. Here are two commercially available tools that run on NI FPGA targets such as NI CompactRIO and NI PXI FlexRIO.
1. StarSim FPGA Express Power Electronics Simulation Tool with Circuit Editor
2. OPAL-RT eHS Power Electronics Simulation Tool (for CompactRIO cRIO-9068 for CompactRIO cRIO-9039)
If you prefer a DIY approach, let me know and I'll share some instructions and references to available IP cores.
08-14-2016 03:11 AM
Thanks for your help! Now If I use PXI-7854R as an inverter controller,I want use a software to simulate inverter circuit,I want to know if there is another software I can use to complete this simulation if I don't use StarSim FPGA Express Power Electronics Simulation Tools with Circuit Editor. Now I have PXI-1082,PXI-8135,PXI-7854R,ComPactRIO 9066,Can I use them complete this simulation.
Dear BMac,If This Video FPGA-based real-time hardware-in-the-loop simulation an rapid prototyping of power electronics can't watch,I can't open this video.If there are somewhere I can find this video?
If I use Veristand, simulink ,visual C++,PXI-7854R,Do you think about this way?
Could you give me some advice and solution?
