Power Electronics Development Center
Guide to Power Electronics Control Application Examples and IP Cores for NI GPIC
Oscar,
have you figured out anything out of this inverter code?
i'm trying to follow the logic but same confused.
on the top, i'm running the vi with complementary pairs phase a, b, upper = 1, phase c lower = 1. Vdc/2 = 100. regardless what currents are set to, the Uan reports -100, Ubn = -100 and Ucn = -2.
to me, Uan Ubn should be 100, Ucn = -100 makes more sense.. so i wonder what is all the logics behind this VI, any one figured out an explanation?
Message 31 of 33
(1,594 Views)
Hello,BMac
Thank you for sharing great work. But all download link is failed.Would you please update download link above or send the code packaging.
Thank you.
and this link you update January 2017 : Click here to download the LabVIEW 2016 library is also failed.
Message 32 of 33
(879 Views)
