Power Electronics Development Center
Three-Level(12 switch) Converter Switching using SVPWM
Hi All ,
I have been coding on FPGA for three-level converter switching. It has couple of errors . I just want to validate my code. How, I don't know.
Can anyone tell me if NI has any build-in block for three-level NPC converter PWM generation for FPGAs.
AAK.
Message 1 of 17
(17,739 Views)
Hello
I am Having the same problem here; I want to make a Three-Level  inverter which has 12 Transistors/Switches, prefferebly with SVPWM method, but I also need some hints.
Could you find anything regarding "Three-Level(12 switch) Converter Switching using SVPWM" ?! Could you please share your findings/simulations?!
Message 2 of 17
(9,724 Views)
Hi ,
The best hint is you have to write your own code for FPGA. There is no help anywhere. Try understanding the commutation of switches properly . If you only want simulations on labview without talking to FPGA, you can do co-simulation. I can send you a Multisim file with built-in pulse generator for 3-level converter.
AAK.
Message 3 of 17
(9,724 Views)
I understand. Well; I will probably need to do it in FPGA too anyway, I guess there is no escape of that!
Thanks...
Message 4 of 17
(9,724 Views)
Sorry dude. I think i can only help you leter, lets say june 2013. Get back to me if you can wait. akrama.khan@hotmail.com
Message 5 of 17
(9,724 Views)
Thank You man,
I will certainly get in touch to see how things are going and share experience...
Message 6 of 17
(9,724 Views)
Most Welcome.
Message 7 of 17
(9,724 Views)
Hey guys,
Here's an approach that should make your work straightforward. I'd recommend using the Space Vector Modulation block included with the NI SoftMotion Module as a starting point. This is a LabVIEW add on module sold by NI. Then modify the vector table to match the three-level neutral-clamped inverter. Here's a screenshot of the standard block with the vector table configured for a standard 2-level, three-phase full-bridge voltage-source inverter.
You can find a complete field-oriented control example with SVPWM in the SoftMotion example project titled "Servo Interface (9514).lvproj".
Here's a screenshot of the LabVIEW FPGA control application in which the FOC and SVPWM blocks are included.
I'd recommend purchasing this book, which has a great treatment of the topic for both the two-level and three-level topologies in Chapter 1. My advisor, Ramu Krishnan, is one of the editors. The book has a great, concise treatment of many modern power converter control strategies, including energy optimal control.
Control in Power Electronics: Selected Problems
Marian P. Kazmierkowski (Editor), Ramu Krishnan (Editor), Frede Blaabjerg (Editor), J. D. Irwin (Series Editor)
Here are some excerpts with SVPWM vectors for 2-level and 3-level NPC inverters.
32-33 Control in Power Electronics- Selected Problems - Space Vectors for 3-Ph 2 and 3 Level Inverters.png
34-35 Control in Power Electronics- Selected Problems - Space Vectors for 3-Ph 2 and 3 Level Inverters.png
36-37 Control in Power Electronics- Selected Problems - Space Vectors for 3-Ph 2 and 3 Level Inverters.png
38-39 Control in Power Electronics- Selected Problems - Space Vectors for 3-Ph 2 and 3 Level Inverters.png
You can validate your LabVIEW FPGA code using the Multisim 3-Phase Inverter, 3-Level NPC example that's included in the Power Electronics Design Guide. You'll need to set it to the Co-Simulation Variant as shown below, and then you can control it from LabVIEW using your SVPWM block.
Here is a direct link to download the Multisim file shown above.
I hope this helps. Let us know how it goes.
Message 8 of 17
(9,724 Views)
Brian, Thank you for your help and also the book suggestion; fortuanately my University has a Subscription to Science Direct database and this book is readable over there!
Message 9 of 17
(9,724 Views)
Hi Saeed !! How is it going with your switching ??
Message 10 of 17
(9,724 Views)
