RF Measurement Devices
wlan constellation calculation get different EVM result compare with result from API
Dear All,
Detail steps is listed below:
1. used rfic devm example:
2 measured EVM is less than -49
3.use constellation points for EVM calculation, the result is -44
I wanna get aligned EVM based on constellation, thanks.
(5,009 Views)
Hi Wei-Smart,
Could you offer more detail message about the issue?
Here is some question:
1, What's the RFmx version?
2, What is the hardware setting?
3, The EVM getting from RFmxWLAN Property Node is different with the EVM caculated from constellation, right?
(4,938 Views)
Hi all.
And also, below you can find the link, full of information about NI RFIC System, Software and Hardware requirements.
NI RFIC
Meri
(4,916 Views)
Hey Youzi,
1.rfmx 1900
2.HW: 5840
3.Yes
Thanks.
(4,906 Views)
Hi Smart,
Could you offer the example that you used?
Thanks.
(4,887 Views)
Accepted by wei-smart
Hi Smart,
The symbols used to calculate EVM are not guaranteed to be a 1:1 correlation with the symbols you see in the constellation map.
In short, this might just be the way it is, and don't try to calculate on your own from the returned symbols, they are there for visualization only and not further processing.
And Where do the data come from?
And the attached VI illustrating a significant increase in performance with a slight adjustment in your ideal symbol map.
(4,868 Views)
