Basic Feature Extraction - Watchdog Agent VI failed to download on cRIO
I'm designing a Real-time application on a NI cRIO-9022, using the Watchdog Agent toolkit made by IMS Center.
While loading my VI on the CompactRIO, I get the following error message:
Deploying SoundVib_Resampling.lvlib:oa_CIC Interpolation Filter.viSoundVib_Resampling.lvlib:oa_CIC Interpolation Filter.vi loaded with errors on the target and was closed.
LabVIEW:  Failed to load shared library sndvib.*:OatCICInterpolatorByMovH:C. Ensure that the library is present on the RT target. Use MAX to install NI software or FTP to transfer custom libraries to the RT target.
I found that when I place the "Basic Feature Extraction" VI inside a "Diagram Disable Structure", the deployment is successful, So the problem comes from this VI.
The error message tells me to install a library on the cRIO but I don't know where to find it.
Thanks for you Help,
David
(5,598 Views)
Hello David,
You probably didn't install the driver on the CRIO. I don't know which driver your VI is using, and you should get in touch with IMS Center for this information (or whoever gave you this VI).
(5,580 Views)
Accepted by Ajyress
Thank you Benoit,
Installing the "sound and vibrations" driver on the cRIO solved the problem Smiley Happy
(5,573 Views)
