Concatenating multiple CAN messages
I am using NI XNET to Tx/Rx CAN messages. LabView 2020 software to display messages.
I need to display a part number received. Part number '4101901-001-SW A' is split into 3 frames and sent via CAN in below format
The table below shows 8 byte data
I am able to display received data in table format. Below is screenshot of Labview application
I need to display this as 4101901-001-SW A. Can you please help me how I can do this
I have byte fields defined in data base. Below logic just displays last received frame.
Thank You
(63 Views)
Single point mode only keeps the most recent data. Use queue mode instead. See the attachment.
Control Lead | Intelline Inc
(31 Views)
